quote:
Is there a different spec for air cooled engines?
No, neither Briggs or Kawasaki references a specific service grade for air cooled 4 cycle engines. If your dealer is using this terminology, it is not an actual spec, but probably a reference to SAE 30 HD.
SAE 30, SAE 10, etc, is a viscosity designation of the oil based on the standards of the Society of Automotive Engineers developed many years ago.
30HD is straight 30 weight detergent oil, and is a common designation used by the petroleum companies, but not an API service grade. HD can be an abbreviation for either "heavy duty" or "high detergent". Non detergent 30 weight oil is labeled SAE 30 SA, with SA being an API designation for non detergent oil.
The current API service grades as recommended by Briggs for use in B&S aircooled 4 cycle engines are SJ (1997-2001) & the current SL which supercedes SJ. This is an automotive crankcase oil spec which is also used in 4 cycle small engines applications.
Here are the various engine oils that B&S is currently selling:
Briggs & Stratton Brand Oils
Hopefully this sorts out the terminology for you.
