A special thanks to Mark Mathys
Hold your ponies there sunruh. First off, you have no idea what kind of maintenance went into this bike. You making a blanket statement like this without knowing the facts is pretty absurd, not to mention rude. FYI, this bike has had more than the recommended maintenance done, including case splits and screen cleans. I don't risk anything when it comes to relying on a piece of equipment to clear an 80 foot gap on a race track. Oil has been changed every three hours, including a filter swap until the Scotts SS filter was installed at 20 hours, and it was solvent cleaned and dried each change. The screen was inspected/cleaned with each valve adjustment at 10 hour intervals, BY THE DEALER. I can read, I have the service manual, and have followed the directions. That being said, why don't you put your time to good use finding a solution to the 04 valvetrain problems instead of bashing someone or thing you haven't got a clue about?quote:
Originally posted by sunruh:
your problems have NOTHING to do with the oil used.
you did NOT follow the manuals specs on cleaning the 2 screens at the recommended intervaults and therefore suffered because of your own inabilities to follow directions. don't blame the oil you use, blame yourself.
From Jibberville where else, I didn't quote any manual, just general view points.quote:
mackelroy,
just WHERE are you getting the jibberish you posted?
you are not even remotely close to what the manuals say.
I have no doubt you know the motor. I do have doubts that you know what I have gone through with this motor. And I stand by my original statement. I am not a fan of this oil. BTW, the Kibblewhite kit, and grooving the intake journal fixes the majority of the 04 issues. But nothing will fix the top end if the screens clog. The permanent fix? A switch to YZ's.quote:
i know WAY more about this motor than you can possibly comprehend.
needs an .006 oil groove in the intake journal.
oem buckets break, they are junk.
two piece valves, worthless.
valve springs are WAY to weak, junk.
if you have black cam cap bolts, you don't have a prayer unless you re-cut the seats to match valve guides. probably needs that anyway.
do you need more info?
the 04 motor isn't worth scrap prices at a recycle center. the 05 is a hair better.
so you really split the cases 5 times?
few people have their motor apart more than together.
beanoil said:The permanent fix? A switch to YZ's.
sands said:I don't see how they sell the stuff at such a steep price.
quote:
Originally posted by Jaybird:
LOL...right on, brother!beanoil said:The permanent fix? A switch to YZ's.
I agree 100% that the YZF's are far more robust out of the box than the honda, kaw/suz, KTM thumpers are. Easier to work on as well.
