I have a '75 Harley sx 175 from the aermacchi- subsidiary era and recently purchased some AMSOIL Dominator oil. I didn't realize at the time that the Interceptor is preferred oil for my bike. I actually discovered the little chart AMSOIL has on their web page that gives the application and the correct oil just last night after weeks of looking for something like that and emails to AMSOIL. Why its not on the oil bottle - I don't know.
Anyway, I still use the injector pump and I had a little Bel Ray 2S in the oil tank left over. Like I said the oil tank was running low and so I topped it off with the Dominator. It seemed good for awhile since it was 2 oils mixed together (I suspect). I'm almost sure this is correct since when I first bought it - I drained whatever oil was in there - and put just AMSOIL and had problems also before draining it again.
It was great with the 2 oils mixed especially in the high rpm range - but now all the Bel ray must of used up and leaving only the Demonator oil in the tank.
Now my bike can't idle and it has trouble starting. I've been messing around with the throttle stop screw and the idle screw a lot which explains why this is occuring. It seemed to run OK when mixed with the Bel ray however. But I'm out of the Bel Ray and all I have left is Mobil 1 Mx-2T.
My question: Can I mix the 2 brands - or should I mix Bel Ray 2s or just bite the bullet on the Dominator and not use it at all? Thanks,
Nick
[ August 16, 2004, 10:27 AM: Message edited by: WetBehindEars ]
Nick
