First off, thanks for the reply Jay.quote:
Originally posted by Jay:
I'm using Delvac 1 in my VFR but I have to buy it by the case which is a 5-yr supply for me. It's also expensive. I would give the Rotella T-Synthetic a try. It's available at any WalMart in qts and gallons. It has very good quality group III basestocks, no friction modifiers, and Shell is highly regarded for their shear-stable polymer VI improvers. We haven't seen an oil analysis on it, though.
First off is that your only reason for bashing synthetic lubricants?quote:
Originally posted by Justin:
Second...tried synthetics before, and it leaked all over the place. Not good!
It has Valvoline Motorcycle 10w-40 (which is "dino oil") sitting in the crankcase right now.
Msparks,quote:
My guess for the leaks that your engine was sludged or varnished so bad that you already had the leaks and the synthetic cleaned it up. Would you rather have a clean engine or a leak. Suggest to get the gaskets replace and use synthetic from then on.
Back to your question. I just put Delo 400 in my 2002 Triumph ST. I'll be running this as an extended breakin oil before I switch to a Synthetic. I'll probably put about 1500 miles on this oil. So far I have 300 miles on it and it runs good. Luckily the weather is somewhat cool now. I'll definately go with a syntehtic before June Rolls around. As this bike runs warm, especially when you run it up around REDLINE!!
Good luck on your choice.
