Originally Posted By: Solarent
I think it is time to update Motor Oil 101. It gets quoted a lot and has helped many people begin to understand some of the basics. Without getting too technical I’ve followed the same general format, but re-written the topics so it is more accurate.
No disrespect to AE Haas, his article has helped many and will continue to do so.
I welcome your comments and input and hopefully if this ends up replacing the current Motor Oil University, the powers that be at BITOG will also take them into consideration.
Chapter One – Operating Temperatures and Viscosity
Understanding what viscosity grades mean can be confusing. The average driver just tries to follow what is in the owners manual – this is a good practice. Some owners manuals allow for different grades for example 0W30 synthetic or 5W30 mineral oil. Others may have a chart which gives recommendations based on the ambient temperatures, and newer engines are recommending even lighter grade oils because there are fuel economy advantages to doing so.
In this chapter we aren’t going to talk about viscosity grades – that will be in chapter 2. In this chapter we will talk about some basic principles of viscosity and how it relates to your engine. For the purposes of this chapter we will talk about viscosity in the unit it is most often measured centistokes (cSt). You don’t have to worry about what that means, but cSt are different from the SAE viscosity grade. For now let’s focus on the basics.
Viscosity is a fluid’s (gas or liquid) resistance to flow. A high viscosity fluid (like molasses) is thick and doesn’t flow easily. A low viscosity fluid (like water) is thin and flows much more easily. For most liquids, the flow rate changes as the temperature of the liquid changes. In engine oil, hot oil has a lower viscosity and flows more easily than cold oil. This is important because your engine – and the oil that is in it runs at a range of temperatures from start up, through the warm up period and at operating temperature.
In the early days of the automobile, engine oils were very simple, basic refined fluids that helped keep moving parts easily sliding past each other. Different oils had different flow rates and there was a very simple way to reference their flow rates relative to each other. Each range of flow rates was assigned a numerical grade. Over time various additives were put into engine oils to allow them to do different things, like changing the flow rate as the temperature changed. Because of these changes the grading system also was changed. But we will talk about that more later.
For now let’s just focus on what happens to a basic oil as the temperature changes. Sometimes confusion occurs because people think in terms of the oil thinning when it gets hot. They think this thinning with heat is the problem with motor oil. It would be more correct to think that oil thickens when it cools to room temperature and THIS is the problem. It is said that 90 percent of engine wear occurs at startup. If we are interested in engine longevity then we should concentrate our attention at reducing engine wear at startup.
Oils recommended by the engine manufacturer is primarily based on giving the right thickness at the normal operating temperature. So let’s focus on that. As an example: If the normal operating temperature is 212F (100C) and the engine needs to operate with an oil viscosity of 10 cSt based on the manual recommendation; then what does that mean for the engine oil at startup when the engine isn’t at 212F? What about during the warm up period? What happens to the oil then? In an ideal world the engine oil viscosity would always be 10 cSt, however in real world terms, the oil thickens as the temperature decreases. If fact, a basic mineral oil thickens so much that it won’t lubricate the engine properly at all. If the oil is 10 cSt at 212F, then at 104F (40C) it thickens up to 100 cSt, and at 32F (0C) to 250cSt and so on. The oil becomes so thick at start-up temperatures that the engine might not even start. There is also real wear that can happen and the engine could break down.
So the easy way to fix this is to just have the oil be 10cSt at startup right? After all if the right viscosity for the engine to operate is 10cSt why not just start there and let it be? The engine would be properly lubricated and no harm. The problem is that if you started at 10cSt then as the engine gets hotter (which they do) then your oil would be much to thin when the engine gets up to operating temperature.
So what do you do – engines have a wide range of start-up temperatures – which even change as the seasons change. How do you get the right operating temperature viscosity when the start-up temperatures are so widely different? In the old days you would use a thicker oil in the summer and a thinner oil in the winter. Today with pressurized water cooled engines, the engine blocks run close to the same operating temperature all year round. As the engine warms up to that temperature the oil starts out too thick and slowly thins out as the temperature increases. This is very inefficient and causes the engine to waste energy slogging through oil that is too thick.
So what you need the right operating temperature viscosity with the flexibility of different startup temperatures you need oil that either doesn’t thicken too much as the temperature decreases and doesn’t thin out too much as the temperature increases. Ideally being as close to 10cSt at start up and then staying close to 10 cSt throughout warm up and up to operating temperature. It won’t be possible to be 10cSt at every temperature, but if we could at least be closer at the colder temperatures that would be better right? So the industry invented an oil that does just that, and called it a multi-grade oil.
