I'm trying to figure out the cooling fan operation on my 2006 G35.
I believe when the A/C is switched on both cooling fans should engage on low speed. I seem to be getting strange operation from my fans.
The driver's side fan wasn't working at all. I checked the wiring and rotated the fan and it spins freely. I turned the A/C on and low and behold it started to work.
Now both fans seems to be working but they are cycling on and off for about 5 seconds when the A/C is running. Is it normal for the fans to cycle on and off even with A/C engaged? The A/C compressor is running continuously so I would think the fans would staying running as well.
