Hi everyone!
I purchased a 36' motorhome last year that didn't have the factory generator anymore. The dealer gave me a Powerhouse PH3100Ri generator, (http://www.powerhouse-products.com/powerhouse_product/ph3100ri/), to make up for the missing geny. What I am trying to do is mount the generator in the bay that held the original factory generator. The actual motor fits, and I have worked out the wiring, cooling and the exhaust,
My problem is the fuel system. The original generator had a fuel pump that would draw fuel from the main RV fuel tank. The Powerhouse generator has a gravity fed carburetor. Originally, I was planning to hook up a low pressure fuel pump and a fuel regulator to feed the generator engine, however, I realized that when the generator was under load, it would require more fuel and I would have to hack some kind of electric valve to allow more fuel on demand.
Now I'm thinking that it would be easier to mount the original fuel tank for the generator in the bay above the generator, but connected to the RV fuel tank with a pump. What I want to do is have some kind of gas tank float that when the fuel goes down to about 1/4 - 1/3 tank, the fuel pump will kick in and refill the generator tank, then turn off when the tank gets to about 2/3 - 3/4 full. This way I don't have to make a complicated system to remove the generator tank every time I need to refill it.
Here are the dimensions on the fuel tank:
15.5" w
16.5" d
6.5" h
Any suggestion would be appreciated!
Thanks
zog
15.5" w
16.5" d
6.5" h
Thanks
zog
