If you are talking ring seating (?), it all depends on the ring. Plasma rings seat easy, Iron rings can be touchy. It all comes down to cylinder wall finish. A hone pattern that will make a set of pressure backed plasma rings happy, prolly will not seat a set of plain iron high tension rings...
Dykes rings, Keystone rings, all these have very specific cylinder wall finishes. And that finish determines the oil needed. Not the guy behind the wheel...
