Originally Posted By: ZeeOSix
Don't quite get your question. The whole nature of a 'full flow' oil filter is that what goes in at rate X also comes out at the same rate X. Of course, if the bypass valve opens up, then what goes out isn't 100% filtered. But if the bypass valve stays closed, then the oil going out is 100% filtered.
Worth noting that the XG5 has no bypass at all, so the oil coming out is always 100% filtered.
You're a GM owner. You should know better! :finger:
Yes, I know about GMs and thier 'in block' bypass valve.
Yes the XG5 might always filter 100% of the oil going through IT, but not necessarily filtering 100% of the oil going to the engine if the in block bypass opens.
I was just knocking your marbles.
