I enjoy reading at Machinery Lubrication and have been running UOA since long before I joined BITOG, but I don't see their correlation holding true in my experience. I most certainly agree that most test labs caution Si ppm above 20; and Mr. Alan Bender (Lab Director at Polaris) has informed me via phone conversation that "Iron and Silicon are the two worst things you can have in your oil." Iron is literally your engine disintegrating (microscopically); and silicon is rock, harder than iron.
Generally, silicon is ingested through your air intake; and not only are there many aftermarket air filters, there are many knowledgeable mechanics who claim that your air filter is the most important filter on your engine. You can do some reading over at Blackstone Labs and they will tell you that there are sources of silicon in your oil other than atmospheric contamination (such as gasket sealer curing from a [recent?] repair), and some antifreezes contain Silicon...It helps to have several UOA reports so that trends can be established.
It also helps to have a virgin oil analysis, because some motor oils have small amounts of Si in their blends as new. I'm running Amsoil 5W30 Full Synthetic, and my
new oil has 6 ppm Si.
If you Wikipedia Silicon, it agrees with what Machinery Lubrication has to say.
https://en.wikipedia.org/wiki/Silicon
Silicon is the eighth most common element in the universe by mass, but very rarely occurs as the pure free element in the Earth's crust. It is most widely distributed in dusts, sands, planetoids, and planets as various forms of silicon dioxide (silica) or silicates. Over 90% of the Earth's crust is composed of silicate minerals, making silicon the second most abundant element in the Earth's crust (about 28% by mass) after oxygen.
I don't think I've ever seen a Used Oil Analysis without
some silicon in it, but the less the better. And I have nothing but logic, but it stands to reason that if Silicon is high in your oil, it would most certainly could have an (abrasive) effect on other metals.
Thanks for posting the article from machinery lubrication, I enjoy reading such. The more sources of information one has, generally the better, and the better chance one has of knowing B*** when one sees it.
