Originally Posted By: cjcride
As Garak said cold starts are the weak point.
There was a prime button for cold starts, but CNG is lighter than air, LPG heavier. So when priming an LPG powered car, the gas fell into the carb, on CNG it went to the top...so CNG was always harder starting. Starting on petrol required forethought, switching over to petrol before you shut off, not really a problem as the carb filled pretty quickly. However, if in the morning you decided you needed petrol, you had to crank the engine over to fill the carb, draing the already marginal battery. I had a Mazda B1600 on CNG, and it had an electric fuel pump, so switching over in the morning was easy.
Before doing a conversion, we always did a cold crank vacuum test - if it couldn't pull a good signal you knew it was going to be a problem child.
