Originally Posted By: minis
I was thinking about adding the RedLine Oil Additive but i thought about how Cera Tec protect the metal surface so i thought i would ask what people thought about it too
Yeabut, the Ceratec will give lower wear figures during breakin than almost any other additive, BUT that means it will slow down the process until at least 100K km. During the break period the driver should try to avoid too much time at idle or more than Max continuous (About 1K below red line). It's also good to vary the RPM during long trips and to avoid dumping the oil early.
So, the typical owner driver is not going to want a car that has advisory RPM restrictions. They want to cruise the city streets, leave the engine at idle for ages when required AND slam the Go pedal around.
I would note that most modern cars do not need a real break in period beyond the first OCI and can even use just a good major brand full synthetic, although they are often high Moly oils.
Oddly enough Fuchs (They are the refinery related company that is the major stock holder in Liqui Moly) are currently top dog of special break in oils for fairly racy German car factory fill applications. Those oils do like like some of the Redlines oils.
