Originally Posted By: CapitalTruck
Originally Posted By: FastLane
Unless you have an aftermarket oil pressure gauge it's all in your head. Factory gauges are not overly sensitive....
By the way, I think you're right. I'm running a PF48E right now and it's just fine, indicated oil pressures are the same (as far as I can tell).
And on top of that, if the oil pressure sensor is after the oil filter (usually is), then the only time you would see any oil pressure change because of an oil filter is when the oil pump is in pressure relief. Would take near redline RPM to see the difference.
You say that, but what explains all the GM bulletins advising the correlation between using a non-ACDelco filter and low oil pressure conditions? Clearly a link has been made between the two. I think years ago people were having the same problem with Purolators.
Do you have a link to said bulletins? If an oil filter is really restrictive, it can make the oil pump go into pressure relief much sooner, and therefor would also cut down the oil flow and pressure seen by the engine. Perhaps that's what they are referring to.
Also, some newer engines have variable output oil pumps (cheesy design IMO), which could have a bearing on how the oil flow and pressure behaves with different oil filters.
