AZjeff
$50 Site Donor 2023
A year and a half ago I parked the 86 Samurai temporarily and it hasn't been started since. It's been under roof and all I did was disconnect the battery. I've recharged the battery several times so it should be ok. I'll drain the gas out of the carb and disconnect the fuel line and crank it enough to get the old gas out of the lines. It's always used some oil but doesn't leak a drop, valve seals or rings? Is this a good time to pull the plugs and try to loosen the rings with a soak of something before I fire it up? Had just changed the oil when I parked it. Anything else I should do? thanks
