Originally Posted By: Silverado12
I use scothbrite pads inside the differential to keep the gears polished because shiny stuff goes faster. Once you drain your oil, rev the engine to the limiter to pump out All the old oil. Trust me, it WILL contaminate the new, esp if synthetic.
Pro tip: Leave the pads in the differential housing so you get continuous polishing.
