Mercedes Benz used to recommend this as a factory-authorized method to cleann lubrication systems. 50/50 oil and kerosene, run for 15 minutes at idle. I have also seen it done where it is allowed to cool down fully, then repeat the idle.
I have used it on cars with suspect oil change histories, etc. If there's a suspected need, it is a legitimate tool. Doing it frequently with regular oil changes would be excessive.
