1977 Toyota Corona. Cranks, won't turn over.
-Made sure it has gas (added about 3-4 gallons).
-Sprayed starter fluid. It will fire for just a second or so, then dies.
-Fuel filter is visible. I can see the gas level in it hasn't changed (after multiple attempts to start).
Does this sound like a likely fuel pump? Or clogged line? How can I test the pump?
I will be changing the filter first.
One other slightly quirk...
The ignition has a push-button start. The key only turns to the ACC position, and then you press a button. Is it possible being in the ACC position is making it fail to start? As mentioned above, there is a brief firing with starter fluid.
Thanks.
Thanks.
