Okay... So the project is pretty much done. Just have to vac and charge the A.C. system, change the rear diff and transmission oil. The project kinda took a turn for the unexpected when I went to replace the seals in the leaking front diff and found lots of metal paste packed in behind the seal. Called the owner and ran over the options- he wanted a re-man. No problem. Ended up using a unit from ZBAG- Zumbrota Bearing and Gear out of Zumbrota Minnesota. 2 year unlimited mileage warranty. Had to wait a few days, got side tracked and busy on other things. Finally got back to it the other day and managed to snap a few pics along the way.
Here is a shot of the paste in behind the output shaft seal- yuck!
I decided to take a bit different approach on installing the new engine. I can honestly say I was dreading it, given how much of a bugger it was to remove. I was pleasantly surprised! Leaving the intake and exhaust manifolds and the secondary air injection tubes off made a huge difference. Obviously I attacked it from the wrong angle when removing it... Sigh...hindsight. Anyway, less than 10 minutes, no swearing and in was nestled nicely in place with 2 bell housing bolts started. Solo.
Leaving the intake off made it much easier to attach most of the wiring harness- which I would have had to navigate through the fender well otherwise.
Other side- not much going on here.
Here it is dropped in place
Exhaust and EGR on
Skipping ahead a few steps- it is pretty much ready to fire in this photo. I put the pre-assembled condenser, radiator (new Delphi), shroud and fan in place in one shot. Then all the front dress stuff.
As an added bonus- no extra parts or fasteners!
Here she is after a pressure wash bath and a short but "spirited" test drive.
And finally- the after video of what it sounds like:
