Description:
This convenient, compact pH Testing Strip kit comes with a pack of pH strips, a color guide, and a compact cylinder case. The strips have a pH range from 1 to 14 (1-6=Acidic, 7=Neutral, 8-14=Basic) for testing solutions for pH level. They're great to use when you need to check the pH of Biodiesel, OIL, isopropyl alcohol, methanol, glycerin, soaps, or any other liquid where a pH level is required. The results are ready within 30 seconds and work extremely well.
