Honesty in advertising
OVERKILL
$100 Site Donor 2021
Ontario, Canada
Hocus Baby Poo Barrel Stabilizer for firearms - Inspired by Lucas, made for women like Katherine
Does your gun lube lack that certain smell and texture? Does it leave you feeling limp and under-performing?
It needs your help!
Do you want to eliminate dry fires, reduce friction, heat and wear? Do you want to dramatically increase barrel life?
You need Hocus!
Formulated from organic, grain fed, mountain grown, free range, non-GMO, alkaline 100% local baby poo, Hocus dramatically improves the performance of your existing lubricant. Through our unique molecular bonding technology, Hocus is 100% compatible with any existing gun lube formulation!
Hocus dramatically improves accuracy because it has what barrels crave: Poolectrolytes!
At only $40 a jug, can you afford NOT to use it?
