I have a basic 2004 Tacoma 2WD X-tra cab that I need to replace the pads and rotors on. The truck is my daily driver which is driven very easily and I never tow anything. I have appx. 163,000 miles on the truck and it runs like a top!
Based on my part number, it seems like my OEM rotors were made by Brembo - http://www.autohausaz.com/pn/4351204010
The price seems pretty good, but I need pads as well. Does anyone have a recommendation for pads and/or a recommendation for a "kit" they like that has both the pads and rotors?
Also, I see my truck has both inner and outer bearings. When you remove the rotor, you just give it a quick tug (with the bearing nut in place) which pops the inner bearing seal cover off as well. Is it possible to re-use the bearing seal or is that a bad idea, and I should just replace the seal?
Ed
Ed
