Originally Posted By: Trav
Originally Posted By: boostedtsiawd
It scared the sht outta me i was like what the [censored] is going on. I was told if i wanna keep the gauge in the middle in these super cold days put a piece of cardboard in front of the radiator but is it really necessary to do that? I just feel like the gauge going down to 165-160f is bad..
Don't put cardboard in front of the radiator, you can seriously overheat the engine and do some damage.
What you describe can be normal depending on where the coolant temp sensor is located. when the thermostat opens it allows cold coolant from the radiator to flow in the engine, the colder ambient temps are the colder the coolant in the radiator.
If the sensor is in that stream the gauge will show a drop, it may not reflect the temperature of the whole system, if you have decent heat and the gauge is steady when its warmer don't worry about it.
LOL, yes I take the cardboard out before summer.
What you really need is an accurate water temp gauge. Most OEM ones are no more than idiot light that got a promotion., Using an OBDII data reader like the Ultra-Gauge will show you what the temp is. Most modern cars have the temp sender where the water is hottest.
