Originally Posted By: Colt45ws
The 4.6L/5.4L 2V share the same cylinder head design, so yeah, both are known to pop plugs. The reason the 5.4L is more known for it IDK.
The 5.4L 3V is the one with the funky plugs that break off.
Around 2003-2004 the Modular 2V engines finally went to the 8-thread heads. My '04 had 8-thread heads.
Even properly torqued they pop. I blew one out a few months ago on my '02.
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3841988/Blown_spark_plug.#Post3841988
Though, I had pulled Autolite plugs out of it, so who knows what the Sheriffs mechanics did to it.
The fact is the margin of error on the 4-thread heads is just not there. I think thats the best way to describe it. I mean, it'll hold but if something is slightly off, the chances of failure are much higher.
You have to do it perfectly.
1. Dead cold engine
2. New clean DRY NICKLE PLATED plugs
3. Torque wrench set to 120in/lbs
And still end up popping one.
On the torque spec you listed- that may be the factory recommended value, but according to a repair service out there, a better torque is 29lbs. Yes, I understand that there are only something like 3 threads, but they claim to have tested them (3 thread heads) to around 100lbs torque without failure of the threads. I've done a few since reading their article and the plugs snug right down with no issues.
