B Brian Barnhart Joined May 26, 2003 Messages 772 Location Ohio Dec 18, 2015 #1 I believe the sodium is from the previous GTX oil change. Last edited: Dec 18, 2015
A aquariuscsm Joined Dec 30, 2006 Messages 29,558 Dec 18, 2015 #2 What brand of oils were these? Did you add MOS2?
B Brian Barnhart Thread starter Joined May 26, 2003 Messages 772 Location Ohio Dec 18, 2015 #3 3 qt. 5W30 Shell, 1 qt. 5W30 Defy, and 2 qt. 0W40 M1. Normally I use only 5W30, but I wanted to see if a little 40 might reduce the engine noise (didn't seem to). No additives that I can recall. Last edited: Dec 18, 2015
A aquariuscsm Joined Dec 30, 2006 Messages 29,558 Dec 18, 2015 #4 Oh ok that must be where the moly came from,the Quaker State Defy.
53' Stude Joined Mar 12, 2015 Messages 28,542 Location In the shop Dec 18, 2015 #5 Some of the moly came from the M1 0w40; please don't forget that
B Brian Barnhart Thread starter Joined May 26, 2003 Messages 772 Location Ohio Dec 19, 2015 #6 I believe the Formula Shell has moly as well.
53' Stude Joined Mar 12, 2015 Messages 28,542 Location In the shop Dec 19, 2015 #7 I realize that also
M Merkava_4 Joined Jan 30, 2007 Messages 17,501 Location Clovis, CA Dec 24, 2015 #8 Try straight 0W-40 next time.
