Originally Posted By: golddredgewater
The owners manuel says to use 5w30, if i used 5w20 would it be safe?
So there is no back-spec, and the manual states that 5w-30 is to be used, no alternates?
If so, 5w-30 it I, IMO.
The logic was at one time that 30 at oils typically shear down into heavy 20wt oils anyway, so might as well formulate a slightly more stout and shear stable 20wt, and run it. Vehicles have been able to use 20wt oils nearly forever, hat makes some of the cafe conspiracies a bit dubious to me, particularly now that we have plenty of vehicles living long life on 20wt oils.
But that said, if the vendor recommends 5w-30, you're best off selecting that viscosity. The use of AFE 0W-30 is a sensible choice too, IMO, if you wish to go syn.
