I really like the Garmin GPS we have. There are several in the family. But the power adapter is a piece of poo. It works, then stops, you wiggle it and maybe it will work again, maybe not. Its got a fuse inside that check OK with ohm meter. Does anyone have a fix?
I tried plugging the GPS into the USB in my car and works OK when the car is off, but turn on the car where it can see the radio and the GPS seems to think its connected to a computer and goes into a mode where it does not do anything (probably waiting to be loaded). Unsure if its charging or not in that mode.
