Originally Posted By: sleddriver
Re: Measuring. While you can take a simple DC resistance meas. with a DVM, I suspect it won't give you the whole story compared to using 20kV, full acceleration, 3000 rpm. High voltage, under load, tends to see resistances quite a bit different than 1.5VDC, with no load.
If you can come up with an effective way of measuring the resistance at 20KV I'll bet the difference is in the noise. Resistance wires are not some magical semiconductor. Within the bounds of temperature and mechanical differences, resistance is resistance. Sure, carbon based resistances can alter characteristics under differing voltage loads, but we are talking in the low percent at worst.
