Depo is not great.
The problem is they look good, but don't fit exactly the same and the optics are not good.
I had to replace lights on a '92 Buick, Depo was the ONLY choice. I could never get the lamps adjusted right, the pattern was just n/g. (either the high beams were too high, or the low beams were too low)
The best is OEM, but once your car is over 10 years old, OEM lamps are hard to come by.. Depo and other Asian companies do serve a purpose, if it was not for them, I would not have been able to replace the lamps and maintain the stock look.
Now OEM in the latter lifecycle of service support is not that great either, HOWERVER, they are using the original molds, so you will get very similar optics.
What happens with OEM service, the molds/processes don't run that often, so everything sits around, some vehicles forward lighting is well past 15 years since end of vehicle production. Very low demand. Things do get dusty, and any replacement lamp you buy, you best to shoot it out with a air gun.
