2014 Honda Accord bought in August as a CPO vehicle with 9550 miles. The coolant overflow bottle was low so I wanted to make sure it wasn't getting into the engine. Dealer topped coolant off and it hasn't moved in 7500 miles.
I wanted to draw a sample out of the dipstick tube but the bends are too sharp for the tubing I had. I bought 29 quarts from AZ last year for a $1 so this oil change cost me $4.20. Refilled with EP. Filter was unchanged and is a Wix 57356XP.
MM just turned 40% which in Honda speak means 40-49% left. I will run the next fill to 15%MM with confidence. The MM to 0% is trending to 14k. 90% highway mileage 3k-4k miles/month. Engine rpm is under 2k at 70mph with the CVT
Lab is ALS/Wix/Napa kit bought from NAPA for $14 p/n 4077 and included TBN. 2 week turnaround time.
Code:
TIME ON UNIT 15802
TIME ON OIL 6228
OIL BRAND Mobil
OIL TYPE Mobil 1 EP
OIL GRADE 0W20
OIL ADDED No
FILTER Wix XP
OIL CHANGED Yes
Metals (ppm)
Iron (Fe) 9
Chromium (Cr)
Lead (Pb)
Copper (Cu) 4
Tin (Sn) 2
Aluminium (Al) 7
Nickel (Ni)
Silver (Ag)
Titanium (Ti)
Vanadium (V)
Contaminants (ppm)
Silicon (Si) 13
Sodium (Na) 13
Potassium (K) 1
Water (%)
Coolant No
Additives (ppm)
Magnesium (Mg) 606
Calcium (Ca) 1218
Barium (Ba)
Phosphorus (P) 609
Zinc (Zn) 699
Molybdenum (Mo) 88
Boron (B) 50
Physical Tests
Viscosity (cSt 100C) 8.3
Fuel (%)
Soot (%) Infrared
Physical / Chemical
Base Number (mgKOH/g) 5.0
Code:
TIME ON UNIT 15802
TIME ON OIL 6228
OIL BRAND Mobil
OIL TYPE Mobil 1 EP
OIL GRADE 0W20
OIL ADDED No
FILTER Wix XP
OIL CHANGED Yes
Metals (ppm)
Iron (Fe) 9
Chromium (Cr)
Lead (Pb)
Copper (Cu) 4
Tin (Sn) 2
Aluminium (Al) 7
Nickel (Ni)
Silver (Ag)
Titanium (Ti)
Vanadium (V)
Contaminants (ppm)
Silicon (Si) 13
Sodium (Na) 13
Potassium (K) 1
Water (%)
Coolant No
Additives (ppm)
Magnesium (Mg) 606
Calcium (Ca) 1218
Barium (Ba)
Phosphorus (P) 609
Zinc (Zn) 699
Molybdenum (Mo) 88
Boron (B) 50
Physical Tests
Fuel (%)
Soot (%) Infrared
Physical / Chemical
