Originally Posted By: Joe90_guy
Once this happens, the mechanism of oil loss changes and you will get severe 'bottom-up' oil loss. The cylinder bore is sprayed/splashed with bulk oil on the piston up-stroke. Normally the oil control ring reduces this to a very thin film of oil on the down stroke. However if this thinning doesn't happen, on the down stroke, hydraulic pressure builds up in the piston-bore gap and will force bulk oil through the second and first ring gaps into the combustion chamber to be burnt. When this happens you're in big trouble!
I'll dig up a link I've got somewhere on piston ring belt residence time, and it was quite shocking that when they put tracer in the oil, the residence time in the ring belt was 10s of seconds, not just a quick fly through. 10s of seconds is forever for the gramme or so of oil in the ring belt, so plenty of time for distillation to take place.
Evidence of much higher additive concentrations in the ring belt, again indicating that the oil is either going AWOL, or turning into something that's no longer liquid.
Further, my pet (educated) theory on varnish has always been that it's formed in the cylinder area, where blowby with it's highly reactive species (NOx, CO, etc.) are working hard against the oxidation stability of the oil.
I've put up that chart before that shows the "average"/common loads/revs for US versus Euro driving, so longer periods with more revs, and more load give you higher ring belt temperatures, higher blowby. etc.
Different courses, so the typical US GF-5 lube may well not cause problems in that world.
Here's the link...note, someone else's work.
