Originally Posted By: DoubleWasp
Face them up. I have a set of H11 LEDs in my Navigator's foglights.
Of course, some will tell you that you're a bad boy for having LED bulbs in a halogen housing, but whatever. Your dime, your choice.
If the OEM housing has no reflector or the OEM bulb tips were painted to shine radially only, then its not just 'your dime, your choice.' A bright, open light source is a hazard. This is why putting HID (or any much higher output lights in stock housings) is no good.
Seriously, what's up with all of the selfish drivers out there, doing what they want despite every other driver on the road. If you wouldn't be OK driving around with your high beams on all night then why would you be OK with an improperly-fitted bulb? Makes no sense.
I really want the higher output LED fogs for the Forester, but they shine omnidirectionally and, now that my wife predominantly drives the Foz I can't be sure she knows to only use them as 'driving' lights. So, I didn't buy them, because, used as 'fog' lights I bet they'd annoy other drivers...
You know, today I saw 2 cop cars with HID converted halogen housings (becoming popular with public vehicles) and I asked them if they have ever heard of an accident being caused by lighting. Their answer was a simple "no".
They did go on to mention that several accidents have been caused by their own emergency lights, due to people braking like idiots, or rubber necking to see what is going on.
Some of you guys really get your panties in a bunch over something that really doesn't matter in the grand scheme of things.
"Hazard" LOL.
And it is his dime and his choice. There's nothing you can or will do to stop him. If he likes them he's going to run them, and if he doesn't, he might not. But you and nobody else will have anything to do with that decision.
So, answer the question: would someone driving behind you or past you with their high beams on bother you at all?
An older Civic? I sometimes cant even tell. A newer car, blinding.
Like every issue, the solution and right answer isn't easy to come by and what may not wad my panties may yours, and vice versa. Seriously, I'm not talking about whiter lights or a cheap, low-output bulb replacement, but BLINDING kits that ARE a hazard.
Case in point, I got stuck behind some jack and ape who's aftermarket lights were SO bright, all three of my rear-facing mirrors were rendered useless and the I could only see the road in front of me as far as his light traveled, the brightness and contrast between his lights and the surrounding perfect darkness was so great.
Most are not nearly that bad, but even an annoyingly bright, scattered light that provides minimal to no benefit to the driver and annoys the heck out of and/or distracts others by a greater amount than zero percent is selfish and stupid.
