I have a question, I have a no-mar wheel balancing stand that I bought along with the no mar tire changer when I used to do track days on a motorcycle. I manually balanced the weights on the stand and tested them up to 160mph many times over and it worked quite well.
The stand also came with large cones for clamping passenger wheels for balancing.
Now I am pretty sure that my ford focus wheels center using the tapered lug nuts.
If I use the cone and clamp the wheel and balance it using the bore/center of the wheel will it cause problems? Are stick on weights ok on OEM aluminum wheels?
This is the balancing stand Im talking about:
http://i.ytimg.com/vi/8KLRf7TtIhY/maxresdefault.jpg
