Car: Saturn Astra XR5.
So I replaced the inner and outer tie rod ends as well as ball joints last night. This afternoon I went and got a front end alignment. The results were that they aligned it and all was well except the rear right toe was out of spec and they cannot fix that since it has a solid "torsion beam" axel; and because of this they could do nothing and it has to stay that way.
Also the car pulls to the right with the steering wheel slightly cocked right, he said this is probably due to the right brakes dragging and causing it to slightly pull right.
Should I take it to another alignment shot for a second opinion as well as is the rear really not alienable??
Thanks everyone.
Thanks everyone.
