Originally Posted By: The_Eric
AS Tegger asked- if it's making what can be described as a whirring noise, and also the noise you described (generally with the covers off), a sticky noise, it's because the belt has been adjusted too tight.
That's what I was getting at. OP would be much further ahead in checking the tension than posting a video of the noise.
The "belt twist" method of checking tension is not reliable, since it depends on the length of the run. The method I describe is better for OP's Honda engine. OP could always post a video showing the slack as I describe checking it. That would be definitive.
