Hi Guys,
I was under my van this weekend patching the gas tank. During the process I noticed that the 4 lines travelling to the rear of the van are corroded around a u shaped bend. Two lines for fuel and the other two for the rear brakes.
The one line which was for the fuel vapor return was actually rusted very badly to the point it broke off. That line fed to a rubber fuel hose. To Macgiver something I had to run to Napa to get 2 feet of fuel vent tubing and replace the shorter piece of tubing.
It worked for now. Does anybody know what the sizes of Fuel line and Brake line are? On the vent line I replaced the hose had an inside diameter of 1/4".
I'm planning on splicing in a new piece and using compression fittings. Any advice would be appreciated. I really don't want to replace the whole line, since they go from the rear all the way up to the firewall and they appear to be a PITA to get too.
