95 Corolla US build, 236k miles, I'd imagine it has a Denso 10PA15C compressor.
It does not make any noise when the AC is not turned on (quiet when AC is off), but when it is on (clutch engaged), it makes low speed howling like noise and I do hear some sort of "spraying" like sound (likely the refrigerant changing phase in the expander).
The system is ice cold but I do see some dark residue on the "belly" of the compressor. 10 years and around 70k miles ago I got into an accident that bent the condenser and it rubbed against the radiator. Didn't realize it at the time and eventually it rubbed into a leak. I replaced the condenser and have a mobile AC guy vacuumed and charged the system.
So do you think it is just normal wear and tear / aging of the system or do you think it is leaking? Should I be concerned about it if it is cold but loud (old car howling, not new car quiet, but not banging or knocking loud either)? I want to drive the car for another 5 years if possible but in our climate a bad AC is enough to send the car to junkyard just as much as head gasket or bad tranny.
