Quote:
It looks like to me that when they are making the filter they need to spread the pleats out more uniform before gluing. I'm not sure more pleats are needed. It just needs better spacing between the pleats.
Perhaps true...maybe. However that being the case, I think the same could be said for 'some' of the Puro anecdotes with a wider than 'other area' seam pleat spacing. In fact I believe I have said that before but basically avoid it as being repetitive. Either way as seen in anecdotes here, the fold back of pleats with wider pleat spacing is a weak point that at some point can lead to bypass.
As noted by a previous poster, had this gone to max rec. 10k miles, moisture/condensation or not, results may not have been as good.
But again, I found pics 3&4 to be very informative for me.
