2003 Volkswagen Jetta TDI with 285,756 miles:
Blackstone: We don't quantify the amount of soot in a sample as part of the standard analysis, but there was enough soot in this sample to prevent us from obtaining an insolubles reading. Excess soot can show a combustion issue but we're not sure if that's the case since that typically comes with a high viscosity as well. Iron is on the high side of average, showing more steel wear than normal. Other wear metals are in good shape compared to universal averages, which shows typical wear with oil run 8,400 miles. The TBN was strong, but run 4K and check back on iron
Aluminum 6
Chromium 6
Iron 94
Copper 4
Lead 2
Tin 1
Molybdenum 71
Nickel 3
Manganese 1
Potassium 13
Boron 33
Silicon 6
Sodium 9
Calcium 937
Magnesium 1103
Phosphorus 1095
Zinc 1274
SUS Viscosity @ 210F 68.6
cSt Viscosity @ 100C 12.57
Flashpoint 430F
Fuel % TBN 7.2
Aluminum 6
Chromium 6
Iron 94
Copper 4
Lead 2
Tin 1
Molybdenum 71
Nickel 3
Manganese 1
Potassium 13
Boron 33
Silicon 6
Sodium 9
Calcium 937
Magnesium 1103
Phosphorus 1095
Zinc 1274
Flashpoint 430F
Fuel % TBN 7.2
