Car's ac blows good at night when it's 75 degrees, but doesn't blow cold air in the daytime when it's 95 degrees. I added the correct amount of refrigerant, but it reads low. 37 psi at 90-95 degrees outside. Someone told me I may have introduced moisture in my system when I emptied it out prior to filling it up causing it to block somewhere. It worked ok the first few days but not anymore unless it's night time. Does anyone know what's wrong?
