It isn't overheating because there is a thermostat. That car came with a thermostat from the factory and that model has likely racked up millions of miles in all weather conditions without overheating.
You have a problem, pulling the thermostat just temporarily HID the problem.
Try a cooling system flush and see if it helps. I would also recommend you get it checked for exhaust gasses in the coolant as a bad head gasket can cause overheating.
