OVERKILL
$100 Site Donor 2021
How much power do you want to make? Lots of good advice in the thread, we all have our own preferences. I've built a few small Windsor's (302's) and I prefer a roller conversion with the readily available link-bar lifters and a decent cam. For OTS a TFS #1 would be really mild, has a wide LSA so the idle is good, nice split-pattern profile, I made 270RWHP (around 320HP flywheel) out of a mild 302 with some ported GT40's with that camshaft. Ran the Crane/Cobra 1.7 radio roller rockers to add some more lift.
Car had a perfectly flat torque curve too, which made it a great driver.
For the intake the Weiand X-Celerator is a good choice unless you prefer a dual-plane. My cam grinder preferred the X-celerator, and we even ran a Victor Jr. on the last carb build my buddy and I did, but that was a 7,000RPM engine.
Carb choice, a vac sec Holley 650 is easy to setup.
Ignition, I'd go with the Duraspark dizzy with an MSD digital box or find a used Crane HI-6. I've used the latter on a couple of cars and it is FANTASTIC. The soft-limiter feature is beautiful and works extremely well.
You WILL need new valvesprings if you intend on retaining those heads. Trickflow will be able to tell you what to run with that cam if you go that route.
For exhaust, I'd do longtubes. Not sure what your budget is but stainless is nice. You want 2.5" collectors into an H or X-pipe. 1 5/8ths primaries should be more than big enough for those heads.
Also, don't forget the little stuff. A 3G alternator and electric fan conversion will make the engine more free-reving and is a cheap upgrade.
