Again: Bla, bla, bla... The tractor will outlive it's usefulness using the $5 Napa. End of story. If you've been around equipment as long as you claim, this should be self-evident.
Originally Posted By: Ramblejam
Originally Posted By: Oil Changer
You do need to pass the torch because your argument is lousy.
See, that's the thing. My intent is different than yours. I'm not here to squabble and argue -- your honestly enjoy it. However, since you want to point out how great your argument is, I have a few suggestions.
1. Stop with the strawman (misrepresenting the position of everyone who has replied).
2. Understand the premise of your position is false cause (correlation/causation).
3. Basing statements on ancedotal experience (what you've observed vs. debating filter construction/cost).
4. Special pleading with each new post (moving the goalposts).
5. Claiming the burden of proof is on someone else.
...and on, and on, and on.
Again, I'm not here to argue. You've just made so many errors in reasoning that it needs to be pointed out for your future benefit.
Valk asked what the "best filter" was for his application, and I was merely guiding him in the right direction. To figuratively spell it out a little more clearly though:
Here's an exploded diagram of the Wix/Napa Gold:
Here's an exploded diagram of the Napa Platinum (Fram Ultra is very similar):
I don't care that it's a Fram -- makes no difference. The Ultra is just a very well constructed filter that's available for around $7.
Good luck, Valk.
