I'm closing in on the 150,000 km (93,750 mi) mark on my Envoy, at which point I have a habit of replacing oxygen sensors on all my vehicles. I've got two heated oxygen sensors on this application, and was looking at the readings of both on my Tech 2 scan tool earlier this morning. Bearing in mind the readings will fluctuate between 0.1V - 0.9V every second, which is roughly 1 Hz, I noticed something peculiar about bank 1.
At idle, HO2S1 will fluctuate between frantically between 39 mV - 911 mV, whilst HO2S2 ranges from 167 mV - 747 mV. HO2S2 seems to be within range (150 - 850 mV), but the drop to 39 mV on HO2S1 got me curious. There are no pending codes stored in the PCM, the A/F ratio is 14.6:1 and the coolant temperature at the time was 191 °F.
I'm replacing them with GM Original Equipment replacements, but was wondering what would trigger the reading to go that low?
