Originally Posted By: FutureDoc
I don't trust that chart unless Canada never saw the MR2 or MR... As the US name phonetically sounds like the word shi... Yup.
Also, I don't trust 0w in the1zz. The MR2 with precat failures is worse than the corolla but 0w is doing no favors... And I will run 0w in my other cars
Curious as to why you are concerned about the oil's ability to flow/pump at -35C? What bearing does that have on the 1ZZ? Are we talking 0w-20, 0w-30, 0w-40, 0w-50? The all carry the 0W-xx designation, so they will all pass the CCS test @ -35C and the MRV test at -40C.
I am not. The 0w was in reference to 0w20, my apologizes for not being clear (on iPad and was lazy switching the keypad). My issue is thinner 0w20 (even 5w20) oil making it to the pre-cats (for ULEV status) which degrades the honeycomb material over a short time. Now, not all markets had this issue and Corolla might or might not have the same number of precats but I believe it was a lot more common for 1ZZ-FED paired with ULEV pre-cats.
Originally Posted By: Garak
I haven't seen any examples on our roads of anything after the first generation, and only a couple examples of the first generation, many years ago. So, perhaps there were few or none, depending upon the model year.
I can expect that the Spyder version was a low seller in Canada (it was in the US) and I expect that pre-2008 models might be an issue as I think y'all had some slightly different crash standards. Then again, the MkII production ran for beyond the 1995 date on the chart (so it is missing two models of the MR2). That might be it but it would be odd if that is the one example of a Yota vehicle being left off the chart (but the Supra was included? Odd...)
