2012 Corolla tire rotation
Eastern Wa.
The owners manual says rotate front to back on the same side, the stock tires are just regular all season not directional or anything. Is this correct? I'm used to getting the tires moving to all points of the car.
The owner manual makes it easy to understand. You don't have to follow the front to rear rotation for non-directional tires according to owner manual, you can rotate according to front wheel drive pattern, so that after 4 rotations any tire will be all corners of the car which is much better than just front and rear of the same side.
It is simple. Your car is Corolla fwd. you will use the 2nd photo provided by bandito440. Htss is right. There is no short cut. Please do the right way.
