Nothing wrong with Mopar filters they are fine just overpriced for what you get IMO. Which Mopar do you use? There are usually Motorcraft equivalents with more features for less money from the exact same manufacturer (Purolator).
I am guessing you can use the Motorcraft FL-910s but not sure which filter you need for sure.
I've been wondering if that will change in both countries now with the Magneti Marelli branding. I do notice that the Mopar filter catalog has expanded significantly with that switch, so something has changed somewhere.
Magneti Marelli....are they related to the Lucas family?
They are purolaters here in the U.S. they are wayyyy overpriced they don't even have a silicone anti drain back valve i use the 090 but would always prefer the wix..
