Originally Posted By: sds911
Peter
I'm not arguing with you. In fact Charles Navarro makes the same recommendation for the acea specs as you do. And states that a lower weight than 15w50 may be fine depending on ambient temps. Read the links I posted and you will find you and he are making similar recommendations.
A40 has served my 996 well for 75000 miles. I'm going with higher zddp oils (dt40, motul, etc) for the next 75k and there is nothing wrong with that since in fact the older formulations of Mobil 1 etc used to have those higher levels for decades. It's cheaper to replace a cat converter then a 20k Porsche engine.
Hi SDS,
I apologise if my tone was perceived as argumentative, that was not my intention.
You raise one of the propositions that I just can't my head around. There seem to be a notion that there are specific brands of specific viscosities that will safeguard an engine from premature destruction and to use any other oils will guarantee damage.
For the cars we love it is widely espoused that high ZDDP and Xw-50 grade oils will save 911 cam lobes, thrust bearings in 928's, big end bearings in 944's and 928's, IMS bearings in M96's etc. I just can't accept that proposition particularly when the reasoning given relies on flawed logic and statistically insignificant and flawed data.
However I do agree that certain oil classifications like ACEA A3/B4 are likely to better for our particular engines and usage but I just don't think we can ever get to the point saying Brand X is better that Brand Y for the same oil classification. Similarly for a street driven 911, I can't see there is any data to support if a Xw-40 is better than a Xw-50 for longevity or vice versa.
In a nutshell, I just don't think there is a "magical" oil in the marketplace that will solve Porsche occasional examples of poor engineering design and practice.
With regard to your intentions with your 996, I can't see any disadvantage moving to a high ZDDP oil as recommended by LN Engineering for the same reasons discussed above.
I apologise again for my previous tone and hope we can keep the discussion going to allow us both to learn.
Regards
