I took the ARX-100 out Wednesday to try some different ammo and see if pulling the barrel resulted in group size shifting.
Some things to consider:
1) Range was 100 yards.
2) I was using a Aimpoint 2MOA optic.
3) I have astigmatism.
4) It was a cloudy day.
5) Combining 2,3,4 means I see the dot as a 'V' shape instead of a clean circle.
6) The stock ARX trigger doesn't help when trying for small groups.
7) I'm not, nor do I pretend to be, anything resembling a sniper.
All that said, here's what my groups looks like:
Ammo from left to right was Geco M193, ADI SS109, PPU 75gr HP, IMI 77gr OTM. The grid is 1" per.
Here's what happened when I pulled the barrel. The barrel was removed after shooting the above groups and left to cool while I was doing some other shooting. I pulled the barrel between each of these groups while I did some other shooting. Ammo was the same Geco M193 as the above target.
BSW
BSW
