The rear brakes on my Traverse got stuck, enough to make one start dragging after I had to make a hard stop. The CR-V I had before needed the pad guides cleaned and lubed annually, and occasionally I had to grind rust off the edges of the backing plates where they slide in the guides. Seems the Traverse needs this too. I had to drive the pads out with a hammer, grind the edges with the Dremel tool, and dab some grease on the guides.
Anybody else have to do this regularly? Is it sufficient to grind the rust off the backing plate edges?
