Originally Posted By: 4wheeldog
Originally Posted By: Jetronic
a tight new engine produces more frictional heat, so is more likely to suffer detonation.
run the highest octane fuel possible.
Please explain how friction increases heat in the combustion chambers? Which is where extra heat would have an effect on detonation.
Actually, new motors are much less likely to develop either ping or detonation, because there is no carbon buildup in the combustion chambers. Older engines often develop knock because of excessive carbon deposits in the cylinders. New motors take quite some time, to have this problem develop.
Friction is very high aroud the piston rings, and this an aera where knock is likely to start. A real problem with GDI engines these days.
A proper petrol or diesel engine doesn't get carbon build up, ever.
